ArubaOS and Controllers
Guest Provisioning - adding required fields
Guest Provisioning - making some of the optional fields into required fields - Is there a way to make some of the optional Guest Field Tabs required. I am running version 3.4.1.1
Re: Guest Provisioning - adding required fields
There is not a way to make them required.
Gary
In a round about more difficult way, you could make your own form (lock it down with a .htaccess file), add a radius user for guest provisioning access so you are only providing the privilege password in the script instead of the main login password, write a script to login to the controller and create the guest provisioning account from the form results.
I know it sounds difficult, but I use automated scripts all the time to perform various functions, such as rebooting the APs on the backup LMS after there has been a network failure to one of the controllers. Once you configure one, the rest are pretty easy.
