ArubaOS and Controllers
Guest provisjoning and Label printer
so we installed a Aruba system at a Hotell for guest access. We also bought a Label printer to print out the generated guest accounts for them, but so far I haven't had much of success in getting prints to this Dymo Laberwriter DUO.
The drivers installs, and the labelprinter works fine with the following software, but when you press print from the guest creation page on the controller web GUI, there comes a blank page. I have tried playing around with the setup a little, but it doens't seem to help much. I believe the problem is how the web browser tries to print the page, that the areas with text is outside the paper/label. I refuse to believe I am the first individual trying to print guest accounts in a label printer, and would be interested in how it has been solved for anyone interestedin sharing.
i have the same problem
i have the same situation. I also think de text is printed outside the area of the label. When i print the generated guest account username and password on a regular A-4 printer, i do get the username/password information.
Did you found a solution already?
Jan Roelof
