ArubaOS and Controllers
HT
Health Check for Aruba Controller Family
Hi all,
If i would like to perform a health checking, any command or GUI task that help to determine the controllers are in good performance i.e cpu, memory, process, AP...etc
Thanks!
Re: Health Check for Aruba Controller Family
You can get the comprehensive picture with 'show tech-support', but that may be a bit heavy for what you intend to see. A simple script that periodically gets the output of the following commands would do the job.
show cpuload
show memory
show storage
show datapath utilization
show processes
show ap database
I use MRTG for monitoring CPU, Interfaces, memory load etc via SNMP. Works very well if something happened to your controller and it rebooted without you capturing the information. I also store syslogs to collect the information from the controller in case something happens.
