Heat map colour codes
Hi is there anywhere I can find out what the color codes represent on the RF Heat Maps ?
Different Channels
They normally represent different channels.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
rf Heat Map
What channels do the different color's represent on the heat map
as I cannot find any reference to this in the user guides I know there was a list on the knowledge base but I no longer seem to have access.
rf Heat Map
It tells you if you mouse over the AP itself.
Channel colors
Like BJ said you can see that if you mouse over, for 2.4ghz .11b/g I see red on channel 1, green on 6 and blue on 11.
Cheers!
Marcus Wehmeyer
Not on 3.4 ?
Thanks Guy's that,s what I know on 3.1 3.3 code etc but on 3.4 it doesn't show you at least on my and one other colleagues PC .
