ArubaOS and Controllers
JYL
Help: how to Export the floor plan from 2.5.6.5 to 3.4.1.0
guys help! how do I export the floor plan I have from 2.5.6.5 controller to my new controller 3.4.1.0? I just need the floor plan.
thanks
JYL
Export
thanks
JYL
JYL,
The Plan tab has an export button. You can then import the plans into 3.4.1.0
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
