Help with 3200
Hi all, I have this problem:
we installed a controller 3200 connected with 11 local AP105, and 1 AP105 connected as RAP.
It happens that about every 15 hours 11 AP105 lose their connection with the controller and reboot, while the RAP does not lose the connection.
Can you help me?
I enclose the controller configuration
Retired Employee
Re: Help with 3200
Can you post the output from
show ap debug system-status ap-name
The Reboot information will give you the answer why the AP rebooted. If it says lost connectivity to the controller then you have to check the behavior of your network when the APs reboot.
One troubleshooting step would be to connect the AP-105 directly to the controller and see if it still reboots every 15 hours.
