ArubaOS and Controllers
Contributor I
How can i trouble mesh ?
Hi all,
I'm new here and I have some problem about Mesh with AP120.
when I show "ap mesh active" and "ap mesh topo" it's show like below.
(OAW-4604_Master_01) #show ap mesh active
Mesh Cluster Name: Mobile-AP-Mesh
Name Group IP Address BSSID Band/Ch/EIRP/MaxEIRP MTU Enet 0/1 Mesh Role Parent #Children AP Type Uptime
Mesh-Point-Mobile-AP Mobile-AP-Group 192.168.91.24 00:24:6c:d9:68:60 802.11g/3/0/0 Tunnel/Tunnel Point - 0 OAW-AP120 5m:59s
Mesh-Portal-Mobile-AP Mobile-AP-Group 192.168.91.23 00:24:6c:d9:67:c0 802.11g/3/24/36 1578 -/Tunnel Portal - 0 OAW-AP120 1h:25m:50s
(OAW-4604_Master_01) #show ap mesh top
Name Mesh Role Parent Path Cost Node Cost Link Cost Hop Count RSSI Rate Tx/Rx Last Update Uplink Age #Children
Mesh-Portal-Mobile-AP Portal (N) - 0 0 0 0 0 - 52s 1h:25m:53s 0
It's seem ap up but mesh point not working.
How can i check the problem?
Thanks in advance.
Aakmit From TH
Not working
Hi all,
Thanks in advance.
Aakmit From TH
When you say "Not working", what part of it is not working?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor I
Re: How can i trouble mesh ?
Hi Colin,
I can't see SSID or access via eth1(wire ap) on mesh point and status power on AP120 alway blink.
(OAW-4604_Master_01) #show ap wired-ap-profile Mobile-AP
Wired AP profile "Mobile-AP"
Parameter Value
Wired AP enable Enabled
Forward mode tunnel
Switchport mode access
Access mode VLAN 91
Trunk mode native VLAN 1
Trunk mode allowed VLANs 1-4094
Trusted Not Trusted
Broadcast Broadcast
I see the log show like below i'm not sure what's that mean.
Sep 13 01:19:41 :311002: |AP Mesh-Point-Mobile-AP@192.168.91.24 sapd| Rebooting: SAPD: Unable to contact switch. Called by sapd_hello_cb:4
thank you for your reply
Aakmit
Unable to Contact Master
You should hardcode the ip address of the master controller when provisioning that mesh AP to ensure that access point can find the controller:
