ArubaOS and Controllers
Occasional Contributor I
How configure default of IP-sec ?
Hi, all.
I had a question about default configration of IP-sec and isakmp in AOS3.2.
If the controller have been unable to initiate to the other controller of responder, how many times will the controller of initiator try to initiate to the controller of responder?
Actually, the local controller could not have relationship of master/local for 5days.
This problem was settled by rebooting local controller.
please anyone advice me!
Re: How configure default of IP-sec ?
`What kind of connection is this? Site to Site VPN? Client to controller VPN? Are both controllers on the same subnet?
To troubleshoot this you need to start security debugging so you an see the ISAKMP messages:
config t
logging level security debugging
show log security
Also, do a "show crypto ipsec sa" to see if there is a security association.
Do a "show datapath session table " to see if any UDP 4500 or protocol 50 traffic is flowing between both controllers.
If you have a site to site VPN setup there is a parameter called "Preconnect" which makes that side of the VPN connection ALWAYS initiate the connection. It tries to establish the connection all the time; there is no limit to the retries. If the VPN tunnel is not up you will NOT be able to ping the network on the other side of the connection, because there is a static route that is established when you create a VPN connection and that network can ONLY be reached if the tunnel is up.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Frequent Contributor II
on os 5.x this level doesn't exsist
(Aruba620) (config) #logging level ?
alerts Immediate action needed
critical Critical Condition
debugging Debug Messages
emergencies System is unusable
errors Error Conditions in the system
informational Informational Messages
notifications Normal but significant condition
warnings Warning condition
what level i've to use to debug only ipsec?
---> found, change the sintax
#logging level debugging security
Andrea Consadori
ACMP 5.0 and 6.3
Sorry,
logging level debug security subcat IKE
logging level debug security subcat vpn
logging level debug security process l2tp
logging level debug security process crypto
