ArubaOS and Controllers
Occasional Contributor I
How do i fix the AP 2.4GHz channel..??
Dear ,
My customer need to fix the AP channel. Is it possible to do it ? How to do it ..?? I need to help, thanks..!!
Aruba controller OS is 3.4.3.2
Aruba
There are multiple methods to do this.
One suggestion:
a) You can disable ARM so that the AP does not 'change channels'... if that is what you mean by 'fixed channel'.
OR if you mean a specific channel (1,6,11...) as a 'fixed channel' instead, you would:
b) you could then set the desired channel under CONFIGURATION/AP CONFIGURATION/SELECT GROUP OR AP SPECIFIC/ RF management/ Then 802.11g or 802.11a Radio profile
c) you will see a setting for 'channel' on the right hand side of this menu. Set the channel to the desired channel and 'apply'
Curious... What is the purpose or desired outcome of fixing the AP channel ?
