ArubaOS and Controllers
How does termination work?
When i deploy the 802.1x authentication,there's an option termination.What's tetrmination's function? Does it affect Radius'authentication or someting?
Any help or suggestion will be appreciated.
Re: How does termination work?
Termination moves the significance of the server certificate from the radius server to the controller. The controller has a built-in certificate, so if you enable termination, that means your radius server does not require a server certificate. Turning on termination also offloads the cpu-intensive process of the certificate process from the radius server to the controller, which allows you to authenticate more 802.1x users at a time.
EAP offload has a drawback if you use a Microsoft IAS or NPS radius server, machine authentication does not work. You do not have this issue with Cisco ACS, Juniper Odyssey or Freeradius servers.
Colin Joseph
Aruba Customer Engineering
