ArubaOS and Controllers
How i will to do clean up flash filesystem ?
i see message from controller after i upgrade firmware ArubaOS
WARNING: There is only 2 MB left on the flash. At least 5 MB of free flash space is recommended to keep the system stable. Please clean-up your flash filesystem.
how i will to do ?
Re: How i will to do clean up flash filesystem ?
You can delete files from the maintenence> File> Delete Files screen.
i use command " dir " for checking after I use command "delete filesyname"
(Aruba620) #dir
-rw-r--r-- 1 root root 8936 Aug 3 13:37 default.cfg
-rw-r--r-- 2 root root 15270 Aug 2 10:56 default.cfg.2011-08-02_10-56-09
drwxr-xr-x 3 root root 0 Aug 2 11:27 fieldCerts
-rw-r--r-- 1 root root 16134 Nov 20 2010 license-save.cfg
-rw-r--r-- 2 root root 15270 Aug 2 10:56 original.cfg
drwx------ 2 root root 0 Aug 2 11:27 tpm
-rw-r--r-- 1 root root 39978 Dec 20 2010 user.db
(Aruba620) #
I use command "show storage" i see the information as below
(Aruba620) >en
Password:******
(Aruba620) #show storage
Filesystem Size Used Available Use% Mounted on
/dev/mtdblock11 156.0M 153.1M 2.9M 98% /flash
none 300.0M 1.5M 298.5M 0% /tmp
/dev/mtdblock9 50.0M 24.3M 25.7M 49% /mnt/img0
/dev/mtdblock10 50.0M 1.5M 48.5M 3% /mnt/img1
(Aruba620) #
Filesystem is used 153.1M why ?
now the partition 1 on the controller is image Bad Aruba OS image
pls see at the attached file ..
I see message error from the controller after i try upgrade firmware
What model controller is this? Do you have Captive Portal files, RF plan files, etc on there?
the controller is mc-620
now it is factory default.
