ArubaOS and Controllers
How to config a web filter in 3400 controller
I cannot find the config option to set up web filter in 3400 controller.
Is it support web filter function?
Aruba
The ArubaOS supports a feature called WALLED GARDEN, its in the userguide as to how to leverage this.
That said, I suspect you are looking for something similar to our CSS offering (external to the controller) to do control of web sites based on categories and such.
CSS is outlined here:
http://www.arubanetworks.com/products/management-security-software-2/content-security-service/
Re: How to config a web filter in 3400 controller
how to have CSS service?
Aruba
You can purchase the CSS service subscription from the Aruba reseller/partner that you obtained the Controller/AP equipment from.
