ArubaOS and Controllers
Frequent Contributor I
I upgraded 3400 Controller to 6.2.1.4. After rebooting controller, RAP3 will not obtain IP.
I upgraded wireless controller 3400 to 6.2.1.4. After rebooting controller, all the RAPs rebooted.
After reboot of RAP3, none of the users are able to obtain an IP address now either wired or wireless.
The get the IP address from their home network and not from the DHCP Server.
When I reboot wireless controller back to the previous verion 6.1.4.1, they are able to obtain an IP address via wired and wireless.
Any suggestions on why they are not able to obtain IP after OS upgrade?
Anthony
Re: I upgraded 3400 Controller to 6.2.1.4. After rebooting controller, RAP3 will not obtain IP.
Do you see any flags on the RAP when you upgraded ?
show ap database
Do you have master-local setup ?
Were you able to see if the user successfully authenticated / associated ?
show ap association client-mac
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thanks for the response.
I checked the RAP for any flags. The following appears;
Name Group AP Type IP Address Status Flags Switch IP
USRAP001 RAP-Group RAP-3WNP 1.1.1.52 Up 18h:48m:29s Rc2 10.38.31.13
USRAP002 RAP-Group RAP-3WNP 1.1.1.45 Up 18h:49m:4s Rc2 10.38.31.13
USRAP003 RAP-Group RAP-3WNP 1.1.1.44 Up 18h:49m:14s Rc2 10.38.31.13
USRAP004 RAP-Group RAP-3WNP 1.1.1.59 Down Rc2 10.38.31.13
USRAP005 RAP-Group RAP-3WNP 1.1.1.151 Down Rc2 10.38.31.13
USRAP006 RAP-Group RAP-3WNP 1.1.1.39 Up 18h:49m:52s Rc2 10.38.31.13
USRAP007 RAP-Group RAP-3WNP 1.1.1.44 Down Rc2 10.38.31.13
USRAP008 RAP-Group RAP-3WNP 1.1.1.117 Down Rc2 10.38.31.13
--More-- (q) quit (u) pageup (/) search (n) repeat
Anthony
Actually, the users are able to successfully authenicate to the RAP via Wireless.
After they authenicate, the system attempts to obtain an IP. That's when it fails.
I have two 3400 controllers operating in a  Master/Standby mode.
Anthony
Do you have enforce-dhcp under the AAA profile ?
You should probably enable:
logging debugging network process dhcpd
logging level debugging user-debug <device mac>
And confirm that the user is able to associate :
and do a show datapath session table <device IP> to make sure there's no denies for the DHCP protocol
I noticed these known issues on the 6.2.1.4 release notes , could these issues apply to you:
Thank you
Victor Fabian
Hi Victor,
Thanks again for your assistance.
The enforce-dhcp is not enabled under the AAA profile. I just confirmed that it's unchecked.
Also, I checked and verified that the ap association:
Association Table
Name bssid mac auth assoc aid l-int essid vlan-id tunnel-id phy assoc. time num assoc Flags
USRAP009 6c:f3:7f:cb:88:10 e0:06:e6:02:3f:f8 y y 1 10 OFFICEWLAN 564 0x10074 g-HT-20sgi-2ss 20m:47s 2 WA
I checked the datapatch session for the one RAP and verified source/destination IP. There was two flags listed:  FC and F. No entries for DHCP Protocol denials.
I looked at the release notes and noticed the session for Remote AP. I was going to run through the steps of removing the Virtual Group. But, I wanted to confirm the steps required to complete this process.
Anthony
Hi Victor,
I removed the RAP-Virtual-AP Group and save the changes. Then I re-added it back to the Virtual AP Group.
No change. The SSID is broadcasting correctly. However, when I connect and authenicate, I'm still getting message 'obtaining IP'...
If I connect laptop to the wired port, I get a IP address 169.xxx.xxx
Anthony
Can you tried upgrading to 6.2.1.3 , I have several RAP3s on that code using Spli-tunnel and Tunnel and I am not experiencing any issues.
I would suggest opening a TAC case too
Thank you
Victor Fabian
Okay. I downloaded vesion 6.2.1.3 and upgraded. After rebooting the controller, the RAPs rebooted.
I checked connectivity on a RAP. Still no luck. I'm able to authenticate to the RAP via Wireless but I cannot obatain an IP.
Also, I'm still not able to obtain IP via the wired port. Getting a 169.254.xxx IP address.
Anthony
Interesting..
How do you have it configured ? Split tunnel/tunnel/bridged mode?
Do you see anything in the logs ? DHCPDISCOVER coming from the client or DHCPOFFER from the dhcp server ?
Thank you
Victor Fabian
