ArubaOS and Controllers
Regular Contributor I
IKE Module Busy , how to manually stop / kill process
hi there,
dont wanna loose my running config, at the moment im stuck in "IKE MODULE BUSY", cant save the config -> startup config
any hidden command? controller is "local" at the moment , running OS 5.0.2.1 , MC 3400
regards
Re: IKE Module Busy , how to manually stop / kill process
If this is a local, please ensure that it has contact with the master to avoid seeing that message. In a local controller, very little of the global config can be configured with the local; most of it is derived from synching with the master. You should reload the controller and see if that message goes away, OR ensure you have ip connectivity with the master.
A command to kill the IKE process would be fine, cause while stuck in connectivity it's not possibiel to save the config e.g. after disabluing "local" controller and set back to "master" controller.
i finally found that some route in the trunk vlans wasnt set (it was a kind of demo environment) , then it finally worked.
regards
You can restart the IKE process by issuing "process restart ike".
