IPv6 with Wired Ports
Hi All,
I have a IPv6 working fine over wireless; if I put a client into this same VLAN but using a wired port (on a RAP5-WN) the client doesn't get an address (IPv4 appears to work fine).
Is there any special (hidden?) configuration option that might need to be enabled? Or any other suggestions for what might be needed?
