ArubaOS and Controllers
Super Contributor II
Integration of device ID and DHCP fingerprinting
Hi All,
I'm very interested in the new DHCP fingerprinting options and the device identification built into the new 6.x code.
What i would like to see is the ability to create a user derivation rule based on a predetermined list of devices rather than having to manually discover the signature and configure it that way.
Are there any plans to incorporate such a feature into the GUI?
It would be good if the device type classification feature in the AAA policy could be designed to work with this a little more smoothly.
Scott
Re: Integration of device ID and DHCP fingerprinting
Scott,
That is a reasonable request. Please contact your Aruba sales team for a RFE or Request for Enhancement.
Thanks Colin, will do!
