ArubaOS and Controllers
Frequent Contributor I
Is there a MIB for a 3600 that will tell me total number of RAPs that are down?
Is there a MIB for a 3600 controller that will tell me the total number of remote APs that are down? I am trying to monitor with nagios and would like to do an snmpget to gather that information so nagios will notify us.
If you have any suggestions on how to monitor with nagios that would also be helpful! Thanks!
Re: Is there a MIB for a 3600 that will tell me total number of RAPs that are down?
I know for a 6000, it is OID .1.3.6.1.4.1.14823.2.2.1.1.3.4.1.6, for down AP count.
I would assume it is the same, if supported on the 3600.
I monitor OID .1.3.6.1.4.1.14823.2.2.1.1.3.1.0, which is number of total APs up, and then I throw a warning if it is not the expected total.
Moderator
The aruba mibs are available for download from the support site. They will detail all of the oids available and what they mean.
Occasional Contributor I
I may be thick, but I'm having trouble locating them on the support site. Any clues?
Try here:  http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/EntryId/9139/Default.aspx
I only see PDF files and web help.
There is documentation for the MIB files, but no link to actually download them. Maybe there's something wrong with my SSO?
Or maybe I'm just really thick.
I apologize.  I sent you to the wrong link.
Try this:  http://support.arubanetworks.com/DOWNLOADSOFTWARE/tabid/75/DMXModule/510/Default.aspx?EntryId=12037
