ArubaOS and Controllers
Super Contributor II
Issue converting IAP-105 to controller
Hi ,
I came across the following error when trying to convert an IAP-105 to a controller (800 series running 5.0.3.3). Screenshot attached.
ap_convert_version_error
This stopped me being able to convert the IAP.
I was able to successfully convert it onto a 650 running 6.1.2.1 and the connected this to the 800 and it downgraded to 5.0.3.3 with no issue.
Is there a minimum release that you can convert to or is this some kind of bug?
Re: Issue converting IAP-105 to controller
Minimum is 6.x to convert. After it is converted you can downgrade, but 6.x is the minimum to convert.
Thanks Colin, very helpful to know!
Contributor I
I attempted this yesterday on 6.0.1.3 and received the same convert error message, although 6.1.2.3 worked fine. I believe the minimum requirement is v6.1.
Contributor II
i have a 200 controller with 5.0.2 code and i can converte the IAP-105 no controller succesfully and it works.
Q: How can i revert the IAP?;)
You should just be able to hit the reset button on the underside of the IAP. There are two image partitions, and the IAP image should be in the backup partition.
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
