ArubaOS and Controllers
L2 bridging from ENET1 on RAP to ethernet port on master controller
I would like to give to a wired client connected on the ENET1 port of a RemoteAP (which terminates on the local switch) L2 access to the same vlan which is also configured on an Ethernet port on the master controller. So I would like to make a bridging from the ENET1 of the RAP through the local controller to the Ethernet port on the master controller. Is that even possible? And if yes, how?
Thank you in advance,
Stefan
Wired ap profile
Stefan
That is exactly what the wired ap profile in the ap group is for. Make that wired ap profile trusted and assign the van to the same vlan that you want the traffic tunneled to.
Re: L2 bridging from ENET1 on RAP to ethernet port on master controller
Thank you Colin for your answer.
I'm using already the wired ap profile and also the port on the RAP is trusted. This way I'm able to bring the user traffic from the RAP to the local controller and out on a Ethernet port on this local controller. However, I would like to bring this traffic further to the master controller. Is this possible too? If yes, is that encapsulated in a gre tunnel or how is the user traffic transported from the local to the master controller?
The setting looks like that:
user client --- RAP --- local controller --- master controller --- Ethernet port on the master controller
I would like to bring the user traffic L2 all the way to the Ethernet port on the master controller.
Stefan
There is an post here http://airheads.arubanetworks.com/vBulletin/showthread.php?t=1485 that describes how you would do this
Thank you Colin for this tip! It solved my problem.
