ArubaOS and Controllers
LAG between Controller and HP Switches
Hi All,
Does anyone have experience of setting up link aggregation (port channel, etherchannel or whatever you want to call it) between Aruba controllers and HP Switches?
I'm familiar with setting up etherchannel between Cisco switches and aruba controllers and was wondering if anyone had any tips or knew any caveats with HP switches?
James
Cheers
James
Super Contributor I
LACP Aruba-HP H3C
HP H3C switch:
interface Bridge-Aggregation10
description "LACP to Aruba WC03"
port link-type trunk
port trunk permit vlan 1 to 2 20 to 21 101 3999
link-aggregation mode dynamic
For each H3C interfaces in LAG:
interface GigabitEthernet1/10/0/24
port link-aggregation group 10
For each Aruba interfaces:
interface fastethernet 1/0
description "FE1/0"
trusted vlan 1-4094
lacp timeout short
lacp group 0 mode passive
You must trusted the lag (thanks to Colin http://airheads.arubanetworks.com/vBulletin/showthread.php?t=4066 )
Int port-channel 0
Trusted
Good luck!
~Trinh Nguyen~
Boys Town
