ArubaOS and Controllers
Lack of licenses for APs
Hello i've recently upgraded my aruba controller to 5.0.2.1 to be able to use
AP93 and AP92. I have more AP licenses than i need, but there are APs that have the L flag.
Is it related to the limits of
Wireless Intrusion Protection Module 40
See my service status output:
Service Status and Current Limits
Access Points 56
Remote Access Points 56
Ortronics Access Points 0
Outdoor Mesh Access Points 256
Voice Service Module Unlimited
VPN Server Module 4096
xSec Module 0
Indoor Mesh Access Points 256
120abg Upgrade 0
121abg Upgrade 0
124abg Upgrade 0
125abg Upgrade 0
Application-Acceleration Remote APs 0
Next Generation Policy Enforcement Firewall Module 56
Wireless Intrusion Protection ENABLED
Policy Enforcement Firewall ENABLED
Remote APs ENABLED
External Services Interface ENABLED
Client Integrity Module ENABLED
VPN Server ENABLED
xSec Module DISABLED
MMC AP DISABLED
Netgear AP DISABLED
Voice Services Module ENABLED
Ortronics AP DISABLED
Mesh Point APs ENABLED
AP Developers Module DISABLED
Internal Test Functions DISABLED
Public Access DISABLED
Application Acceleration DISABLED
Policy Enforcement Firewall for VPN users DISABLED
Content Security DISABLED
Re: Lack of licenses for APs
Yes, it's the WIP license, the rule is:
AP == WIP == PEF
The smallest of these licenses is the limit, which is why they need to match. The system doesn't have a method to apply licenses to only certain APs, so you'll need to up the WIP license to match the AP license in your case.
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
Thanks I've deleted the WIP license and now it works.
Now my roof is on the PEF licenses.
I'll have to buy more of both.
Thanks alot
It looks like your AP and PEF are the same, so you'll actually need more of all three if you're going beyond the current 56 number, and remember for 6.0 that things like tarpit and spectrum analysis require the RFProtect (WIP) license. Your WIP licenses will get converted when you upgrade to RFProtect. Your current network:
Access Points 56
-awl
Andy Logan, ACDX
Aruba Networks
