Lacp
Do you know of any more specific documentation on LACP besides what is in the manual? I noticed that LACP will automatically inherit a port channel's properties. So is the best method to lag 2 ports together is maybe to set up a port channel for the ports first? What happens if there is not a port channel? If anyone has setup LACP on their M3's, please share.
Angela Hollman
Re: Lacp
It is better to setup the port channel first; that way, when you add the interfaces they will be configured as you want them in the port channel. Either way, when doing any aggregation of ports, we would encourage you to do the configuration using the serial port of the controller, just in case you make an error (you probably already know this).
Below is a snippet of LACP configuration (not necessarily in order):
=== CISCO SWITCH CONFIG ====================
interface FastEthernet6/39
switchport access vlan 14
switchport mode access
channel-group 2 mode active
spanning-tree portfast
interface FastEthernet6/40
interface FastEthernet6/41
interface Port-channel2
description Connected to Aruba-Controller
switchport
=== ARUBA CONFIG ===========================
interface gigabitethernet 1/1
description "GE1/1"
trusted
trusted vlan 1-4094
lacp group 2 mode active
interface gigabitethernet 1/2
description "GE1/2"
trusted
trusted vlan 1-4094
interface gigabitethernet 1/3
description "GE1/3"
trusted
trusted vlan 1-4094
interface port-channel 2
trusted
trusted vlan 1-4094
=== ARUBA LACP SHOW COMMANDS ===============
(SWF) #show lacp 2 neighbor
Flags: S - Device is requesting slow LACPDUs
F - Device is requesting fast LACPDUs
A - Device is in Active mode P - Device is in Passive mode
LACP Neighbor Table
Port Flags Pri OperKey State Num Dev Id
GE 1/2 SA 32768 0x2 0x3d 0xc0 00:13:19:6A:4D:80
GE 1/3 SA 32768 0x2 0x3d 0xc2 00:13:19:6A:4D:80
GE 1/1 SA 32768 0x2 0x3d 0xc1 00:13:19:6A:4D:80
(SWF) #show lacp 2 counters
LACP Counter Table
Port LACPDUTx LACPDURx MrkrTx MrkrRx MrkrRspTx MrkrRspRx ErrPktRx
GE 1/2 95 92 0 0 0 0 0
GE 1/3 96 90 0 0 0 0 0
GE 1/1 92 88 0 0 0 0 0
(SWF) #show lacp 2 internal
LACP Internal Table
Port Flags Pri AdminKey OperKey State Num Status
GE 1/2 SA 255 0x3 0x3 0x3d 0x3 up
GE 1/3 SA 255 0x3 0x3 0x3d 0x4 up
GE 1/1 SA 255 0x3 0x3 0x3d 0x2 up
(SWF) #show lacp sys-id
32768,00:0B:86:61:66:14
(SWF) #show interface port-channel 2
Port-Channel 2 is administratively up
Hardware is Port-Channel, address is 00:00:00:00:00:00 (bia 00:0B:86:61:66:17)
Description: Link Aggregate (LACP)
Spanning Tree is forwarding
VLAN membership: 1
Switchport priority: 0
Member port:
GE 1/2, Admin is up, line protocol is up
GE 1/3, Admin is up, line protocol is up
GE 1/1, Admin is up, line protocol is up
Last clearing of "show interface" counters 0 day 0 hr 52 min 54 sec
link status last changed 0 day 0 hr 21 min 27 sec
34355 packets input, 2882907 bytes
Received 10165 broadcasts, 0 runts, 0 giants, 0 throttles
456 input error bytes, 0 CRC, 0 frame
4811 multicast, 24190 unicast
17102 packets output, 1904307 bytes
0 output errors bytes, 0 deferred
0 collisions, 0 late collisions, 0 throttles
Port-Channel 2 is TRUSTED
Lacp
Thanks for your response. I will be trying this shortly. I appreciate the CLI commands. That is where I usually work.
Ang
Re: Lacp
switchport
description "GE1/1"
trusted
trusted vlan 1-4094
description "GE1/2"
trusted
trusted vlan 1-4094
description "GE1/3"
trusted
trusted vlan 1-4094
trusted
trusted vlan 1-4094
Wouldn't you be creating an access port on the Cisco with vlan 14 in one end and a 802.1q trunk on the Aruba with vlan 1-4094? If so vlan 14 would be untagget from the Cisco port and would be recognized by as Aruba as vlan 1 (as the default untagged vlan)?
Re: Lacp
There is no word "Trunk" on the Aruba side. It would be an access port.
Frequent Contributor I
Re: Lacp
Do make sure that the ports have the same setting when configuring LACP...
Just my 2 cents...
Michael
Lacp
Now I'm a bit confused. I usually set up my controllers with trunk ports. I am not using a Cisco switch so that config is irrelevant. But I am trunking my controller ports....
int gig 0/0
switchport mode trunk
switchport trunk native vlan xxx
switchport trunk allowed vlan add xxx
So I have planned on mirroring whatever I do in the port-channel on the physical ports just in case.
Re: Lacp
You would configure all of the layer2 trunk commands that you would normally configure under the interface, under the port channel, instead e.g:
config t
switchport trunk native vlan 5
switchport trunk allowed vlans all
