ArubaOS and Controllers
Load Balancing Between Two Internet Connections
Is it possible in Aruba OS, that we can load balance internet traffic between two uplinks from ISP?
As per my search, there can only be 1 default gateway so it is not possible.
Is there any other way to route specific VLAN data through a specific Internet VLAN?
Note that the Internet IP is via DHCP from modem so we cant do static routing to a specific public address.
Re: Load Balancing Between Two Internet Connections
No.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor I
While you may not be able to do this directly from the Aruba controller, you might be able to add a "router/L3 switch" between the controller and the two Internet connections. The router/L3 switch might have more "tools" to leverage to provide the traffic balancing you are looking to implement.
