Load Balancing
I have configured Load Balancing on an AP Group and assigned about 30 access points to it. These are the settings:
AP Load Balancing: On
AP Load Balancing Max Retries: 8
AP Load Balancing User High Watermark: 10
AP Load Balancing User Low Watermark: 8
However when I turn on around 25 laptops they all associate to one access point and they don't load between any of the other access points in the area. Any ideas ?
I have also disabled local probe response within the SSID profile. As recommended on the Aruba support site.
Knowledgebase Answer 276
David,
If you login to the support site, and look in the knowledgebase under answer 276, it has a rather lengthy article with screenshots on how to configure and monitor this feature.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
