ArubaOS and Controllers
Lost Authenication to SSH and Web
Hi All,
Up until this afternon I was access the controller via a LDAP Server Group which gave me the root role to log into the controller.
No I can't do it and got to use local username and password checked setting nothing changed and can log in fine with the same rules on my other controllers.
I keep getting this in the security log
Oct 14 16:21:37 :125025: |aaa| Radius Authentication is disabled
But I am not using Radius... Can any one help me please.
Re: Lost Authenication to SSH and Web
I suspect that this message is being reused by the system to mean either LDAP or RADIUS. Did anyone make any config changes?
Can you get physical access and login via the console? There is a password recovery system if you don't have a local admin setup detailed here, but you need to be on the console:
http://airheads.arubanetworks.com/vBulletin/showthread.php?t=3934
If that doesn't work I'd open a support case.
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
