ArubaOS and Controllers
M3 Controller Throughput
I see from the data sheet of the controller that the Aruba M3 Controller Module has an Encrypted throughput (AES-CCM) of 4Gbps. Please let me know if this is only for the SSID that is running with AES?
Is this applicable to the entire controller when AES is enabled?
Thanks!
Re: M3 Controller Throughput
That figure is the total AES encryption performance of the controller, whatever the configuration is...
Oguzhan Eren
