ArubaOS and Controllers
M3 controller crashing because of Hard Watchdog Reset
I have an M3 controller running that crashes and reboots a couple times a month. I have contacted tech support and they don't have an answer to why this is happening. They just tell me to upgrade to the latest code or they recommend a version. Does anyone have the same problem or experienced an unexpected reboot. I have about 366 AP on the M3 controller.
Number of Reasons
There are a number of reasons why a controller would crash. If support takes your crash.tar and tells you to upgrade to a version, they normally ask you to do it for a reason. Obtain the exact reason and upgrade is your only option.
You could stay where you are and continue crashing, or take their recommendation and hold them responsible. That is the way it works.
Colin Joseph
Aruba Customer Engineering
