MIB Help!
I'm trying to graph a number of things (like connections per radio) directly into cacti using snmp queries, but I've having trouble identifying the index items in the MIBS; every time I try to snmpwalk an item tagged as index, it tells me that the value does not exist. I think I'm just misunderstanding something; can anyone give me some pointers?
Contributor II
Re: MIB Help!
From my experience the major of the MIBS aplies to the APs, yo query the controller but providing AP name as parameter. I could provide a sample nagios check that I rewrited based on some ones work. (Only little modifications)
