Contributor I
MMS and 3.4
We are in the process of planning an upgrade to 3.4.x and have found out that MMS (which we use) has not been tested above 3.3.1
Is there anybody out there using MMS on a code rev above 3.3.1? If so, did you have any issues with MMS?
Thanks in advance for any input.
Contributor I
Re: MMS and 3.4
Sorry, upgrade target code is 3.3.3.x
Re: MMS and 3.4
Hi Steve,
MMS went end-of-support in Sept. 09. It might still be able to monitor the controllers, but you probably won't get all the configuration and will need to configure the devices using the master. You probably want to talk to your account team about upgrading to AirWave as soon as you can, we have moved almost everyone off MMS at this point.
thanks,
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
