ArubaOS and Controllers
Mac OS is not work if i enable 802.1x machine authentication
I setup 802.1x with machine authentication with one role (that is Machine-role)
I setup 802.1x with user authentication with one role (that is authenticated-role)
My windows-xp and windows-7 join to domain that is not problem it is work with 802.1x machine authentication
but My Mac OS is not work with 802.1x machine authentication
My problem is Mac OS con't get ip address from DHCP Server after i was logon (ctrl-alt-deleate) and can't change role ot authenticated-role
please...
Re: Mac OS is not work if i enable 802.1x machine authentication
That is because a mac is not really part of the domain, so it cannot pass machine authentication.
Is this mac bound to the domain? If so, please try the suggestion here: http://www.esecurityplanet.com/views/article.php/3899996/How-to-Use-Enterprise-Wi-Fi-Encryption-and-8021X-in-Mac-OS-X.htm
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
thanks
