ArubaOS and Controllers
Mapping AP Group to an SSID
Can some help with my brain fart. I have done this more times then I can count but not for a while now. I can't figure out how to map an AP Group to an SSID.
Any pushing, nudging, punching to get my brain to start working again would be great.
Ed
Re: Mapping AP Group to an SSID
Go to Configuration> Wireless > AP Configuration. Edit the AP group that you want to add/remove a wireless network. Expand Wireless and add or remove the virtual AP that you want to show up in that AP group.
As always thank you!
