Contributor I
Mesh Link less RSSI
Implementing a mesh link for one of the customer , mesh portal and point is up.
Mesh portal Antenna is inside the glass building and signal is attenuated to some level and only one led is shown in the RSSI indicator. Is there any way to improve this by playing around the channels or any other parameters. I am trying to operate on lower channels but not happening, it is falling back to one of the higher channels.
AP is AP-85 and the antenna is AP-ANT-89
