Mesh MAC technique
Hi all,
i want to know what is the Medium access control technique that aruba uses in the mesh architecture is it CSMA/CA like the ordinary Wi-Fi client or there are some more MAC techniques like TDD or some thing to coordinate medium access between mesh nodes and mesh portal
why so ? i need to know what will be the actual TCP/IP throughput of the mesh cluster (1 mesh portal with 9 mesh points) and the MAC technique will definitely affect the throughput, also i'm designing the RF of the solution so that each mesh point - mesh portal link runs with the 54Mbps rate
thanks in advance
