Mesh design
Dear ALL:
A customer need to connect wireless point to point between two buildings (on the beach) the distance between the two buildings = 150-200 m|(open area).
Note that the customer wants the minimum cost and didn't want to pay annual NTRA license.
My Suggested BOM
1-controller 620
2- 2 AP 92
3- we need your advice for choosing the appropriate antenna which achieve the required performance and it must
enter Egypt successfully.
the suggested antennas(ANT-6,ANT-2 X2-2005)
