ArubaOS and Controllers
Contributor I
Mobile clients *sometimes* not connecting properly
This is a weird one.
WPA2 encrypted network with a captive portal. But some clients we use MAC authentication to avoid having to login to the portal (mobile devices). My Android device is one of them.
Often times I'll connect fine, but sometimes I don't. I'll see the phone say it's connected to the SSID, then 'obtaining IP address from ', then back to 'Scanning'. It'll cycle through this a few times, then say failed, then start all over.
On the controller, I can see my mobile device listed. If I do a #aaa user delete mac , my phone will then connect fine.
I'll lose connection again if I roam and latch onto another AP.
It's become increasingly infuriating.
Unfortunately I don't know all the tools to help diagnose this issue. Does anyone have any thoughts?
One 5000 master controller and two 6000 locals, all running ArubaOS 3.3.2.19-FIPS. Half of our AP61s LMS_IP point to one 6000, half to the other.
Contributor I
Re: Mobile clients *sometimes* not connecting properly
Just tested...
I'm connected with my Android. I turn off WiFi. I turn WiFi back on. It won't get an IP address again until I remove my Android's entry from the user-table.
Basic Troubleshooting
1. Put your device in debug logging on the controller: conf t, logging level debugging user-debug your-device-mac
2. Simulate the failure
3. Now look at the logs: show log user-debug all | include your-mac-address
This is a great thing to do prior to calling TAC, as they will eventually ask you to do this.
Let us know what you find!
Zach
Zach Jennings
Contributor I
Sweet! Thanks for the debugging tip. I knew it was possible, just not how to go about it.
Now, can you help make some sense of this gobbeldy gook?
Here's the log of my mobile trying unsuccessfully to associate and connect to the network:
Nov 2 08:01:18 :501095:   |stm|  Assoc request @ 08:01:18.257639: 98:4b:4a:70:93:e4 (SN 1): AP 153.103.216.115-00:0b:86:ac:87:90-1.1.10
Nov 2 08:01:18 :501100: |stm| Assoc success @ 08:01:18.259032: 98:4b:4a:70:93:e4: AP 153.103.216.115-00:0b:86:ac:87:90-1.1.10
Nov 2 08:01:18 :501065: |stm| Sending STA 98:4b:4a:70:93:e4 message to Auth and Mobility Unicast Encr WPA2 PSK AES Multicast Encr WPA2 PSK AES VLAN 0x3
Nov 2 08:01:18 :522035: |authmgr| MAC=98:4b:4a:70:93:e4 Station UP: BSSID=00:0b:86:ac:87:90 ESSID=NatickSSC-Guest VLAN=3 AP-name=1.1.10
Nov 2 08:01:18 :522004: |authmgr| MAC=98:4b:4a:70:93:e4 ingress 0x10ce (tunnel 110), u_encr 32, m_encr 32, slotport 0x1020
Nov 2 08:01:18 :522004: |authmgr| MAC=98:4b:4a:70:93:e4 IP=0.0.0.0: MAC auth start: entry-type=L2, bssid=00:0b:86:ac:87:90, essid=NatickSSC-Guest sg=default
Nov 2 08:01:18 :500511: |mobileip| Station 98:4b:4a:70:93:e4, 0.0.0.0: Received association on ESSID: NatickSSC-Guest Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name 1.1.10 Group AP1.1.10-ap-group BSSID 00:0b:86:ac:87:90, phy g, VLAN 3
Nov 2 08:01:18 :500010: |mobileip| Station 98:4b:4a:70:93:e4, 0.0.0.0: Mobility trail, on switch 153.103.12.4, VLAN 3, AP 1.1.10, NatickSSC-Guest/00:0b:86:ac:87:90/g
Nov 2 08:01:18 :522039: |authmgr| MAC=98:4b:4a:70:93:e4 IP=0.0.0.0 Authentication result=Authentication Successful method=MAC server=Internal
Nov 2 08:01:18 :522004: |authmgr| MAC=98:4b:4a:70:93:e4 IP=0.0.0.0: MAC auth success: entry-type=L2, bssid=00:0b:86:ac:87:90
Nov 2 08:01:18 :522004: |authmgr| MAC=98:4b:4a:70:93:e4 def_vlan 3 derive vlan: 0 auth_type 2 auth_subtype 2
Nov 2 08:01:18 :522029: |authmgr| MAC=98:4b:4a:70:93:e4 Station authenticated: method=MAC, role=natickssc-open-guest-role, VLAN=3/3/0
Nov 2 08:01:18 :522004: |authmgr| {0.0.0.0} autTable ("98:4b:4a:70:93:e4 Authenticated MAC natickssc-open-guest-role ")
Nov 2 08:01:49 :501105: |stm| Deauth from sta: 98:4b:4a:70:93:e4: AP 153.103.216.115-00:0b:86:ac:87:90-1.1.10 Reason Unspecified Failure
Nov 2 08:01:49 :501065: |stm| Sending STA 98:4b:4a:70:93:e4 message to Auth and Mobility Unicast Encr WPA2 PSK AES Multicast Encr WPA2 PSK AES VLAN 0x3
Nov 2 08:01:49 :522036: |authmgr| MAC=98:4b:4a:70:93:e4 Station DN: BSSID=00:0b:86:ac:87:90 ESSID=NatickSSC-Guest VLAN=3 AP-name=1.1.10
Nov 2 08:01:49 :522004: |authmgr| MAC=98:4b:4a:70:93:e4 ingress 0x10ce (tunnel 110), u_encr 32, m_encr 32, slotport 0x1020
Nov 2 08:01:49 :500511: |mobileip| Station 98:4b:4a:70:93:e4, 0.0.0.0: Received disassociation on ESSID: NatickSSC-Guest Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name 1.1.10 Group AP1.1.10-ap-group BSSID 00:0b:86:ac:87:90, phy g, VLAN 3
Nov 2 08:01:49 :501000: |stm| Station 98:4b:4a:70:93:e4: Clearing state
Nov 2 08:02:10 :501095: |stm| Assoc request @ 08:02:10.205470: 98:4b:4a:70:93:e4 (SN 1): AP 153.103.216.115-00:0b:86:ac:87:90-1.1.10
Nov 2 08:02:10 :501100: |stm| Assoc success @ 08:02:10.206734: 98:4b:4a:70:93:e4: AP 153.103.216.115-00:0b:86:ac:87:90-1.1.10
Nov 2 08:02:10 :501065: |stm| Sending STA 98:4b:4a:70:93:e4 message to Auth and Mobility Unicast Encr WPA2 PSK AES Multicast Encr WPA2 PSK AES VLAN 0x3
Nov 2 08:02:10 :500511: |mobileip| Station 98:4b:4a:70:93:e4, 0.0.0.0: Received association on ESSID: NatickSSC-Guest Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name 1.1.10 Group AP1.1.10-ap-group BSSID 00:0b:86:ac:87:90, phy g, VLAN 3
Nov 2 08:02:10 :522035: |authmgr| MAC=98:4b:4a:70:93:e4 Station UP: BSSID=00:0b:86:ac:87:90 ESSID=NatickSSC-Guest VLAN=3 AP-name=1.1.10
Nov 2 08:02:10 :522004: |authmgr| MAC=98:4b:4a:70:93:e4 ingress 0x10ce (tunnel 110), u_encr 32, m_encr 32, slotport 0x1020
Nov 2 08:02:10 :522004: |authmgr| MAC=98:4b:4a:70:93:e4 IP=0.0.0.0: MAC auth start: entry-type=L2, bssid=00:0b:86:ac:87:90, essid=NatickSSC-Guest sg=default
Nov 2 08:02:10 :522039: |authmgr| MAC=98:4b:4a:70:93:e4 IP=0.0.0.0 Authentication result=Authentication Successful method=MAC server=Internal
Nov 2 08:02:10 :522004: |authmgr| MAC=98:4b:4a:70:93:e4 IP=0.0.0.0: MAC auth success: entry-type=L2, bssid=00:0b:86:ac:87:90
Nov 2 08:02:10 :522004: |authmgr| MAC=98:4b:4a:70:93:e4 def_vlan 3 derive vlan: 0 auth_type 2 auth_subtype 2
Nov 2 08:02:10 :522029: |authmgr| MAC=98:4b:4a:70:93:e4 Station authenticated: method=MAC, role=natickssc-open-guest-role, VLAN=3/3/0
Nov 2 08:02:10 :522004: |authmgr| {0.0.0.0} autTable ("98:4b:4a:70:93:e4 Authenticated MAC natickssc-open-guest-role ")
Nov 2 08:02:42 :501105: |stm| Deauth from sta: 98:4b:4a:70:93:e4: AP 153.103.216.115-00:0b:86:ac:87:90-1.1.10 Reason Unspecified Failure
Nov 2 08:02:42 :501065: |stm| Sending STA 98:4b:4a:70:93:e4 message to Auth and Mobility Unicast Encr WPA2 PSK AES Multicast Encr WPA2 PSK AES VLAN 0x3
Nov 2 08:02:42 :522036: |authmgr| MAC=98:4b:4a:70:93:e4 Station DN: BSSID=00:0b:86:ac:87:90 ESSID=NatickSSC-Guest VLAN=3 AP-name=1.1.10
Nov 2 08:02:42 :522004: |authmgr| MAC=98:4b:4a:70:93:e4 ingress 0x10ce (tunnel 110), u_encr 32, m_encr 32, slotport 0x1020
Nov 2 08:02:42 :500511: |mobileip| Station 98:4b:4a:70:93:e4, 0.0.0.0: Received disassociation on ESSID: NatickSSC-Guest Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name 1.1.10 Group AP1.1.10-ap-group BSSID 00:0b:86:ac:87:90, phy g, VLAN 3
Nov 2 08:02:42 :501000: |stm| Station 98:4b:4a:70:93:e4: Clearing state
Now here's the log showing me deleting the mac from the user table, and the subsequent successful association and connection:
Nov 2 08:04:16 :522004:   |authmgr|  MAC=98:4b:4a:70:93:e4 IP=172.16.1.120 Send mobility delete message, flags=0x0
Nov 2 08:04:16 :522005: |authmgr| MAC=98:4b:4a:70:93:e4 IP=172.16.1.120 User entry deleted: reason=user request
Nov 2 08:04:16 :522004: |authmgr| MAC=98:4b:4a:70:93:e4 Send Station delete message to mobility
Nov 2 08:04:16 :522004: |authmgr| 98:4b:4a:70:93:e4: station datapath entry deleted
Nov 2 08:04:16 :501074: |stm| wifi_deauth_sta: bad data, dropping. mac: 98:4b:4a:70:93:e4 bssid: 00:0b:86:36:36:a1
Nov 2 08:04:33 :501095: |stm| Assoc request @ 08:04:33.900541: 98:4b:4a:70:93:e4 (SN 1): AP 153.103.216.115-00:0b:86:ac:87:90-1.1.10
Nov 2 08:04:33 :501100: |stm| Assoc success @ 08:04:33.901826: 98:4b:4a:70:93:e4: AP 153.103.216.115-00:0b:86:ac:87:90-1.1.10
Nov 2 08:04:33 :501065: |stm| Sending STA 98:4b:4a:70:93:e4 message to Auth and Mobility Unicast Encr WPA2 PSK AES Multicast Encr WPA2 PSK AES VLAN 0x3
Nov 2 08:04:33 :522035: |authmgr| MAC=98:4b:4a:70:93:e4 Station UP: BSSID=00:0b:86:ac:87:90 ESSID=NatickSSC-Guest VLAN=3 AP-name=1.1.10
Nov 2 08:04:33 :522004: |authmgr| MAC=98:4b:4a:70:93:e4 ingress 0x10ce (tunnel 110), u_encr 32, m_encr 32, slotport 0x1020
Nov 2 08:04:33 :522004: |authmgr| MAC=98:4b:4a:70:93:e4 IP=0.0.0.0: MAC auth start: entry-type=L2, bssid=00:0b:86:ac:87:90, essid=NatickSSC-Guest sg=default
Nov 2 08:04:33 :500511: |mobileip| Station 98:4b:4a:70:93:e4, 0.0.0.0: Received association on ESSID: NatickSSC-Guest Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name 1.1.10 Group AP1.1.10-ap-group BSSID 00:0b:86:ac:87:90, phy g, VLAN 3
Nov 2 08:04:33 :522039: |authmgr| MAC=98:4b:4a:70:93:e4 IP=0.0.0.0 Authentication result=Authentication Successful method=MAC server=Internal
Nov 2 08:04:33 :522004: |authmgr| MAC=98:4b:4a:70:93:e4 IP=0.0.0.0: MAC auth success: entry-type=L2, bssid=00:0b:86:ac:87:90
Nov 2 08:04:33 :522004: |authmgr| MAC=98:4b:4a:70:93:e4 def_vlan 3 derive vlan: 0 auth_type 2 auth_subtype 2
Nov 2 08:04:33 :522029: |authmgr| MAC=98:4b:4a:70:93:e4 Station authenticated: method=MAC, role=natickssc-open-guest-role, VLAN=3/3/0
Nov 2 08:04:33 :522004: |authmgr| {0.0.0.0} autTable ("98:4b:4a:70:93:e4 Authenticated MAC natickssc-open-guest-role ")
Nov 2 08:04:35 :522026: |authmgr| MAC=98:4b:4a:70:93:e4 IP=172.16.1.120 User miss: ingress=0x10ce, VLAN=3
Nov 2 08:04:35 :522006: |authmgr| MAC=98:4b:4a:70:93:e4 IP=172.16.1.120 User entry added: reason=Sibtye
Nov 2 08:04:35 :522008: |authmgr| User authenticated: Name=98:4b:4a:70:93:e4 MAC=98:4b:4a:70:93:e4 IP=172.16.1.120 method=MAC server=Internal role=natickssc-open-guest-role
Nov 2 08:04:35 :522004: |authmgr| {172.16.1.120} autTable ("98:4b:4a:70:93:e4 Authenticated MAC natickssc-open-guest-role ")
I'm still looking them over, but I wanted to get the logs up here as soon as I could.
One glaring difference out of the gate, is that in the first log, I'm seeing the station has an IP of 0.0.0.0; obviously a problem. Even while the mobile is not connecting, the user table shows it having a valid IP. Observe (this is before deleting the 'bogus' entry):
(NatickAruba6000-2) (config) # show user
Users
IP MAC Name Role Age(d:h:m) Auth VPN link AP name Roaming Essid/Bssid/Phy Profile
172.16.1.120 98:4b:4a:70:93:e4 98:4b:4a:70:93:e4 natickssc-open-guest-role 00:00:25 MAC 1.1.10 Associated NatickSSC-Guest/00:0b:86:ac:87:90/g natickssc-guest-aaa-profile
So it appears that the user-table has my mobile at 172.16.1.120, while the logs seem to think my mobile's IP address is 0.0.0.0. After a bit, the logs show a of a Deauth of the station giving an Unspecified Failure. While that's not very helpful, it's probably because the station has an invalid IP?
So I guess I need to figure out why the mobile comes in as 0.0.0.0, and then doesn't get a DHCP address...
Oh, and I notice these settings: Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled. Should any of these be tweaked?
Whew. Coffee time.
Frequent Contributor II
Similar issue
I'm experiencing what I feel is a similar issue with an iPhone 4 with iOS 5. My Desktop Mac running Lion will connect and stay connected without an issue on an AP and I can't seem to get a thing running on my iPhone. I turn on WIFI and fire it back up and it will work for a few seconds then stop.
Here are some of my logs.
(aruba-master) #show log user-debug all
Nov 2 07:36:04 :501102: |stm| Disassoc from sta: 60:c5:47:5a:64:7f: AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS Reason STA has left and is disassocisted
Nov 2 07:36:04 :501065: |stm| Sending STA 60:c5:47:5a:64:7f message to Auth and Mobility Unicast Encr WPA2 PSK AES Multicast Encr WPA2 PSK AES VLAN 0x1, wmm:1, rsn_cap:0
Nov 2 07:36:04 :501102: |AP PPS@10.110.42.24 stm| Disassoc from sta: 60:c5:47:5a:64:7f: AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS Reason STA has left and is disassocisted
Nov 2 07:36:04 :522036: |authmgr| MAC=60:c5:47:5a:64:7f Station DN: BSSID=d8:c7:c8:96:60:c0 ESSID=Castle Wireless VLAN=1 AP-name=PPS
Nov 2 07:36:04 :522004: |authmgr| MAC=60:c5:47:5a:64:7f ingress 0x10c4 (tunnel 68), u_encr 32, m_encr 32, slotport 0x1040 , type: local, FW mode: 0, AP IP: 0.0.0.0
Nov 2 07:36:04 :522004: |authmgr| station free: bssid=d8:c7:c8:96:60:c0, valid=1, @=0x1089e054
Nov 2 07:36:04 :500511: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Received disassociation on ESSID: Castle Wireless Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name PPS Group Castle BSSID d8:c7:c8:96:60:c0, phy g, VLAN 1
Nov 2 07:36:04 :501000: |AP PPS@10.110.42.24 stm| Station 60:c5:47:5a:64:7f: Clearing state
Nov 2 07:36:04 :501000: |stm| Station 60:c5:47:5a:64:7f: Clearing state
Nov 2 07:36:13 :501095: |stm| Assoc request @ 07:36:13.012501: 60:c5:47:5a:64:7f (SN 15): AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office
Nov 2 07:36:13 :501095: |AP Superintendent's Office@10.110.42.37 stm| Assoc request @ 07:36:13.010430: 60:c5:47:5a:64:7f (SN 15): AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office
Nov 2 07:36:13 :501100: |AP Superintendent's Office@10.110.42.37 stm| Assoc success @ 07:36:13.011511: 60:c5:47:5a:64:7f: AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office
Nov 2 07:36:13 :501100: |stm| Assoc success @ 07:36:13.016071: 60:c5:47:5a:64:7f: AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office
Nov 2 07:36:13 :501065: |stm| Sending STA 60:c5:47:5a:64:7f message to Auth and Mobility Unicast Encr WPA2 PSK AES Multicast Encr WPA2 PSK AES VLAN 0x1, wmm:1, rsn_cap:0
Nov 2 07:36:13 :500511: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Received association on ESSID: Castle Wireless Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name Superintendent's Office Group Castle BSSID d8:c7:c8:96:5d:90, phy g, VLAN 1
Nov 2 07:36:13 :522035: |authmgr| MAC=60:c5:47:5a:64:7f Station UP: BSSID=d8:c7:c8:96:5d:90 ESSID=Castle Wireless VLAN=1 AP-name=Superintendent's Office
Nov 2 07:36:13 :500010: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Mobility trail, on switch 10.110.40.240, VLAN 1, AP Superintendent's Office, Castle Wireless/d8:c7:c8:96:5d:90/g
Nov 2 07:36:13 :522004: |authmgr| MAC=60:c5:47:5a:64:7f ingress 0x108a (tunnel 10), u_encr 32, m_encr 32, slotport 0x1040 , type: local, FW mode: 0, AP IP: 0.0.0.0
Nov 2 07:36:13 :522004: |authmgr| MAC=60:c5:47:5a:64:7f def_vlan 1 derive vlan: 0 auth_type 0 auth_subtype 0
Nov 2 07:36:30 :501095: |stm| Assoc request @ 07:36:30.056299: 60:c5:47:5a:64:7f (SN 223): AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:36:30 :501095: |AP PPS@10.110.42.24 stm| Assoc request @ 07:36:29.989722: 60:c5:47:5a:64:7f (SN 223): AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:36:30 :501100: |AP PPS@10.110.42.24 stm| Assoc success @ 07:36:29.990825: 60:c5:47:5a:64:7f: AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:36:30 :501065: |stm| Client 60:c5:47:5a:64:7f moved from AP Superintendent's Office to AP PPS
Nov 2 07:36:30 :501065: |stm| Sending STA 60:c5:47:5a:64:7f message to Auth and Mobility Unicast Encr WPA2 PSK AES Multicast Encr WPA2 PSK AES VLAN 0x1, wmm:1, rsn_cap:0
Nov 2 07:36:30 :500511: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Received disassociation on ESSID: Castle Wireless Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name Superintendent's Office Group Castle BSSID d8:c7:c8:96:5d:90, phy g, VLAN 1
Nov 2 07:36:30 :522036: |authmgr| MAC=60:c5:47:5a:64:7f Station DN: BSSID=d8:c7:c8:96:5d:90 ESSID=Castle Wireless VLAN=1 AP-name=Superintendent's Office
Nov 2 07:36:30 :501080: |stm| Deauth to sta: 60:c5:47:5a:64:7f: Ageout AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office STA has left and is deauthenticated
Nov 2 07:36:30 :522004: |authmgr| MAC=60:c5:47:5a:64:7f ingress 0x108a (tunnel 10), u_encr 32, m_encr 32, slotport 0x1040 , type: local, FW mode: 0, AP IP: 0.0.0.0
Nov 2 07:36:30 :501100: |stm| Assoc success @ 07:36:30.062572: 60:c5:47:5a:64:7f: AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:36:30 :501105: |AP Superintendent's Office@10.110.42.37 stm| Deauth from sta: 60:c5:47:5a:64:7f: AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office Reason STA has left and is deauthenticated
Nov 2 07:36:30 :501000: |AP Superintendent's Office@10.110.42.37 stm| Station 60:c5:47:5a:64:7f: Clearing state
Nov 2 07:36:30 :522004: |authmgr| station free: bssid=d8:c7:c8:96:5d:90, valid=1, @=0x1089e054
Nov 2 07:36:30 :500511: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Received association on ESSID: Castle Wireless Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name PPS Group Castle BSSID d8:c7:c8:96:60:c0, phy g, VLAN 1
Nov 2 07:36:30 :500010: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Mobility trail, on switch 10.110.40.240, VLAN 1, AP PPS, Castle Wireless/d8:c7:c8:96:60:c0/g
Nov 2 07:36:30 :522035: |authmgr| MAC=60:c5:47:5a:64:7f Station UP: BSSID=d8:c7:c8:96:60:c0 ESSID=Castle Wireless VLAN=1 AP-name=PPS
Nov 2 07:36:30 :522004: |authmgr| MAC=60:c5:47:5a:64:7f ingress 0x10c4 (tunnel 68), u_encr 32, m_encr 32, slotport 0x1040 , type: local, FW mode: 0, AP IP: 0.0.0.0
Nov 2 07:36:30 :522004: |authmgr| MAC=60:c5:47:5a:64:7f def_vlan 1 derive vlan: 0 auth_type 0 auth_subtype 0
Nov 2 07:38:44 :501102: |stm| Disassoc from sta: 60:c5:47:5a:64:7f: AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS Reason STA has left and is disassocisted
Nov 2 07:38:44 :501065: |stm| Sending STA 60:c5:47:5a:64:7f message to Auth and Mobility Unicast Encr WPA2 PSK AES Multicast Encr WPA2 PSK AES VLAN 0x1, wmm:1, rsn_cap:0
Nov 2 07:38:44 :501102: |AP PPS@10.110.42.24 stm| Disassoc from sta: 60:c5:47:5a:64:7f: AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS Reason STA has left and is disassocisted
Nov 2 07:38:44 :500511: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Received disassociation on ESSID: Castle Wireless Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name PPS Group Castle BSSID d8:c7:c8:96:60:c0, phy g, VLAN 1
Nov 2 07:38:44 :501000: |AP PPS@10.110.42.24 stm| Station 60:c5:47:5a:64:7f: Clearing state
Nov 2 07:38:44 :522036: |authmgr| MAC=60:c5:47:5a:64:7f Station DN: BSSID=d8:c7:c8:96:60:c0 ESSID=Castle Wireless VLAN=1 AP-name=PPS
Nov 2 07:38:44 :522004: |authmgr| MAC=60:c5:47:5a:64:7f ingress 0x10c4 (tunnel 68), u_encr 32, m_encr 32, slotport 0x1040 , type: local, FW mode: 0, AP IP: 0.0.0.0
Nov 2 07:38:44 :522004: |authmgr| station free: bssid=d8:c7:c8:96:60:c0, valid=1, @=0x1089e054
Nov 2 07:38:44 :501000: |stm| Station 60:c5:47:5a:64:7f: Clearing state
Nov 2 07:38:48 :501095: |stm| Assoc request @ 07:38:48.322580: 60:c5:47:5a:64:7f (SN 8): AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:38:48 :501100: |stm| Assoc success @ 07:38:48.325580: 60:c5:47:5a:64:7f: AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:38:48 :501065: |stm| Sending STA 60:c5:47:5a:64:7f message to Auth and Mobility Unicast Encr WPA2 PSK AES Multicast Encr WPA2 PSK AES VLAN 0x1, wmm:1, rsn_cap:0
Nov 2 07:38:48 :500511: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Received association on ESSID: Castle Wireless Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name PPS Group Castle BSSID d8:c7:c8:96:60:c0, phy g, VLAN 1
Nov 2 07:38:48 :522035: |authmgr| MAC=60:c5:47:5a:64:7f Station UP: BSSID=d8:c7:c8:96:60:c0 ESSID=Castle Wireless VLAN=1 AP-name=PPS
Nov 2 07:38:48 :522004: |authmgr| MAC=60:c5:47:5a:64:7f ingress 0x10c4 (tunnel 68), u_encr 32, m_encr 32, slotport 0x1040 , type: local, FW mode: 0, AP IP: 0.0.0.0
Nov 2 07:38:48 :522004: |authmgr| MAC=60:c5:47:5a:64:7f def_vlan 1 derive vlan: 0 auth_type 0 auth_subtype 0
Nov 2 07:38:48 :501095: |AP PPS@10.110.42.24 stm| Assoc request @ 07:38:48.277158: 60:c5:47:5a:64:7f (SN 8): AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:38:48 :501100: |AP PPS@10.110.42.24 stm| Assoc success @ 07:38:48.289546: 60:c5:47:5a:64:7f: AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:38:49 :501095: |stm| Assoc request @ 07:38:49.057779: 60:c5:47:5a:64:7f (SN 11): AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:38:49 :501100: |stm| Assoc success @ 07:38:49.058581: 60:c5:47:5a:64:7f: AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:38:49 :501065: |stm| Sending STA 60:c5:47:5a:64:7f message to Auth and Mobility Unicast Encr WPA2 PSK AES Multicast Encr WPA2 PSK AES VLAN 0x1, wmm:1, rsn_cap:0
Nov 2 07:38:49 :500511: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Received association on ESSID: Castle Wireless Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name PPS Group Castle BSSID d8:c7:c8:96:60:c0, phy g, VLAN 1
Nov 2 07:38:49 :522035: |authmgr| MAC=60:c5:47:5a:64:7f Station UP: BSSID=d8:c7:c8:96:60:c0 ESSID=Castle Wireless VLAN=1 AP-name=PPS
Nov 2 07:38:49 :522004: |authmgr| MAC=60:c5:47:5a:64:7f ingress 0x10c4 (tunnel 68), u_encr 32, m_encr 32, slotport 0x1040 , type: local, FW mode: 0, AP IP: 0.0.0.0
Nov 2 07:38:49 :522004: |authmgr| MAC=60:c5:47:5a:64:7f def_vlan 1 derive vlan: 0 auth_type 0 auth_subtype 0
Nov 2 07:38:49 :501095: |AP PPS@10.110.42.24 stm| Assoc request @ 07:38:49.008070: 60:c5:47:5a:64:7f (SN 11): AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:38:49 :501100: |AP PPS@10.110.42.24 stm| Assoc success @ 07:38:49.048710: 60:c5:47:5a:64:7f: AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:38:49 :501095: |stm| Assoc request @ 07:38:49.562426: 60:c5:47:5a:64:7f (SN 17): AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office
Nov 2 07:38:49 :501095: |AP Superintendent's Office@10.110.42.37 stm| Assoc request @ 07:38:49.467657: 60:c5:47:5a:64:7f (SN 17): AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office
Nov 2 07:38:49 :501100: |AP Superintendent's Office@10.110.42.37 stm| Assoc success @ 07:38:49.468439: 60:c5:47:5a:64:7f: AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office
Nov 2 07:38:49 :501065: |stm| Client 60:c5:47:5a:64:7f moved from AP PPS to AP Superintendent's Office
Nov 2 07:38:49 :500511: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Received disassociation on ESSID: Castle Wireless Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name PPS Group Castle BSSID d8:c7:c8:96:60:c0, phy g, VLAN 1
Nov 2 07:38:49 :522036: |authmgr| MAC=60:c5:47:5a:64:7f Station DN: BSSID=d8:c7:c8:96:60:c0 ESSID=Castle Wireless VLAN=1 AP-name=PPS
Nov 2 07:38:49 :522004: |authmgr| station free: bssid=d8:c7:c8:96:60:c0, valid=1, @=0x1089e054
Nov 2 07:38:49 :501080: |stm| Deauth to sta: 60:c5:47:5a:64:7f: Ageout AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS STA has left and is deauthenticated
Nov 2 07:38:49 :501100: |stm| Assoc success @ 07:38:49.569846: 60:c5:47:5a:64:7f: AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office
Nov 2 07:38:49 :500511: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Received association on ESSID: Castle Wireless Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name Superintendent's Office Group Castle BSSID d8:c7:c8:96:5d:90, phy g, VLAN 1
Nov 2 07:38:49 :522035: |authmgr| MAC=60:c5:47:5a:64:7f Station UP: BSSID=d8:c7:c8:96:5d:90 ESSID=Castle Wireless VLAN=1 AP-name=Superintendent's Office
Nov 2 07:38:49 :500010: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Mobility trail, on switch 10.110.40.240, VLAN 1, AP Superintendent's Office, Castle Wireless/d8:c7:c8:96:5d:90/g
Nov 2 07:38:49 :522004: |authmgr| MAC=60:c5:47:5a:64:7f ingress 0x108a (tunnel 10), u_encr 32, m_encr 32, slotport 0x1040 , type: local, FW mode: 0, AP IP: 0.0.0.0
Nov 2 07:38:49 :501105: |AP PPS@10.110.42.24 stm| Deauth from sta: 60:c5:47:5a:64:7f: AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS Reason STA has left and is deauthenticated
Nov 2 07:38:49 :501000: |AP PPS@10.110.42.24 stm| Station 60:c5:47:5a:64:7f: Clearing state
Nov 2 07:38:51 :501095: |stm| Assoc request @ 07:38:51.505529: 60:c5:47:5a:64:7f (SN 93): AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:38:51 :501065: |stm| Client 60:c5:47:5a:64:7f moved from AP Superintendent's Office to AP PPS
Nov 2 07:38:51 :501065: |stm| Sending STA 60:c5:47:5a:64:7f message to Auth and Mobility Unicast Encr WPA2 PSK AES Multicast Encr WPA2 PSK AES VLAN 0x1, wmm:1, rsn_cap:0
Nov 2 07:38:51 :500511: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Received disassociation on ESSID: Castle Wireless Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name Superintendent's Office Group Castle BSSID d8:c7:c8:96:5d:90, phy g, VLAN 1
Nov 2 07:38:51 :522036: |authmgr| MAC=60:c5:47:5a:64:7f Station DN: BSSID=d8:c7:c8:96:5d:90 ESSID=Castle Wireless VLAN=1 AP-name=Superintendent's Office
Nov 2 07:38:51 :522004: |authmgr| MAC=60:c5:47:5a:64:7f ingress 0x108a (tunnel 10), u_encr 32, m_encr 32, slotport 0x1040 , type: local, FW mode: 0, AP IP: 0.0.0.0
Nov 2 07:38:51 :522004: |authmgr| station free: bssid=d8:c7:c8:96:5d:90, valid=1, @=0x1089e054
Nov 2 07:38:51 :501080: |stm| Deauth to sta: 60:c5:47:5a:64:7f: Ageout AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office STA has left and is deauthenticated
Nov 2 07:38:51 :501100: |stm| Assoc success @ 07:38:51.512552: 60:c5:47:5a:64:7f: AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:38:51 :500511: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Received association on ESSID: Castle Wireless Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name PPS Group Castle BSSID d8:c7:c8:96:60:c0, phy g, VLAN 1
Nov 2 07:38:51 :500010: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Mobility trail, on switch 10.110.40.240, VLAN 1, AP PPS, Castle Wireless/d8:c7:c8:96:60:c0/g
Nov 2 07:38:51 :522035: |authmgr| MAC=60:c5:47:5a:64:7f Station UP: BSSID=d8:c7:c8:96:60:c0 ESSID=Castle Wireless VLAN=1 AP-name=PPS
Nov 2 07:38:51 :501105: |AP Superintendent's Office@10.110.42.37 stm| Deauth from sta: 60:c5:47:5a:64:7f: AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office Reason STA has left and is deauthenticated
Nov 2 07:38:51 :522004: |authmgr| MAC=60:c5:47:5a:64:7f ingress 0x10c4 (tunnel 68), u_encr 32, m_encr 32, slotport 0x1040 , type: local, FW mode: 0, AP IP: 0.0.0.0
Nov 2 07:38:51 :501000: |AP Superintendent's Office@10.110.42.37 stm| Station 60:c5:47:5a:64:7f: Clearing state
Nov 2 07:38:51 :522004: |authmgr| MAC=60:c5:47:5a:64:7f def_vlan 1 derive vlan: 0 auth_type 0 auth_subtype 0
Nov 2 07:38:51 :501095: |AP PPS@10.110.42.24 stm| Assoc request @ 07:38:51.409125: 60:c5:47:5a:64:7f (SN 93): AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:38:51 :501100: |AP PPS@10.110.42.24 stm| Assoc success @ 07:38:51.462535: 60:c5:47:5a:64:7f: AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:52:22 :522004: |authmgr| AU0(0), HA1, TAP0, PARP0 OIP0 IIP0 INT0 WD0 FW0 DT1
Nov 2 07:52:22 :522004: |authmgr| MAC=60:c5:47:5a:64:7f IP=10.110.42.226 Send mobility delete message, flags=0x0
Nov 2 07:52:22 :522004: |authmgr| {10.110.42.226} datapath entry deleted
Nov 2 07:52:22 :522005: |authmgr| MAC=60:c5:47:5a:64:7f IP=10.110.42.226 User entry deleted: reason=user request
Nov 2 07:52:22 :522004: |authmgr| MAC=60:c5:47:5a:64:7f Reset station role to authenticated (48) (ingress=4292)
Nov 2 07:52:22 :522004: |authmgr| download: ip=0.0.0.0 acl=48/0 role=authenticated, Ubwm=0, Dbwm=0 tunl=0x10c4, PA=0, HA=1, RO=0, VPN=0
Nov 2 07:52:22 :501106: |stm| Deauth to sta: 60:c5:47:5a:64:7f: Ageout AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS wifi_deauth_sta
Nov 2 07:52:22 :501065: |stm| Sending STA 60:c5:47:5a:64:7f message to Auth and Mobility Unicast Encr WPA2 PSK AES Multicast Encr WPA2 PSK AES VLAN 0x1, wmm:1, rsn_cap:0
Nov 2 07:52:22 :500511: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Received disassociation on ESSID: Castle Wireless Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name PPS Group Castle BSSID d8:c7:c8:96:60:c0, phy g, VLAN 1
Nov 2 07:52:22 :500010: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Mobility trail, on switch 10.110.40.240, VLAN 1, AP PPS, Castle Wireless/d8:c7:c8:96:60:c0/g
Nov 2 07:52:22 :522036: |authmgr| MAC=60:c5:47:5a:64:7f Station DN: BSSID=d8:c7:c8:96:60:c0 ESSID=Castle Wireless VLAN=1 AP-name=PPS
Nov 2 07:52:22 :522004: |authmgr| MAC=60:c5:47:5a:64:7f ingress 0x10c4 (tunnel 68), u_encr 32, m_encr 32, slotport 0x1040 , type: local, FW mode: 0, AP IP: 0.0.0.0
Nov 2 07:52:22 :522004: |authmgr| station free: bssid=d8:c7:c8:96:60:c0, valid=1, @=0x1089e054
Nov 2 07:52:22 :522004: |authmgr| MAC=60:c5:47:5a:64:7f Send Station delete message to mobility
Nov 2 07:52:22 :522004: |authmgr| 60:c5:47:5a:64:7f: station datapath entry deleted
Nov 2 07:52:22 :501080: |stm| Deauth to sta: 60:c5:47:5a:64:7f: Ageout AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS Denied; Ageout
Nov 2 07:52:22 :501000: |stm| Station 60:c5:47:5a:64:7f: Clearing state
Nov 2 07:52:22 :501105: |AP PPS@10.110.42.24 stm| Deauth from sta: 60:c5:47:5a:64:7f: AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS Reason STA has left and is deauthenticated
Nov 2 07:52:22 :501000: |AP PPS@10.110.42.24 stm| Station 60:c5:47:5a:64:7f: Clearing state
Nov 2 07:52:33 :501095: |stm| Assoc request @ 07:52:33.865598: 60:c5:47:5a:64:7f (SN 15): AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office
Nov 2 07:52:33 :501095: |AP Superintendent's Office@10.110.42.37 stm| Assoc request @ 07:52:33.807517: 60:c5:47:5a:64:7f (SN 15): AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office
Nov 2 07:52:33 :501100: |AP Superintendent's Office@10.110.42.37 stm| Assoc success @ 07:52:33.808260: 60:c5:47:5a:64:7f: AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office
Nov 2 07:52:33 :501100: |stm| Assoc success @ 07:52:33.868391: 60:c5:47:5a:64:7f: AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office
Nov 2 07:52:33 :501065: |stm| Sending STA 60:c5:47:5a:64:7f message to Auth and Mobility Unicast Encr WPA2 PSK AES Multicast Encr WPA2 PSK AES VLAN 0x1, wmm:1, rsn_cap:0
Nov 2 07:52:33 :500511: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Received association on ESSID: Castle Wireless Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name Superintendent's Office Group Castle BSSID d8:c7:c8:96:5d:90, phy g, VLAN 1
Nov 2 07:52:33 :500010: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Mobility trail, on switch 10.110.40.240, VLAN 1, AP Superintendent's Office, Castle Wireless/d8:c7:c8:96:5d:90/g
Nov 2 07:52:33 :522035: |authmgr| MAC=60:c5:47:5a:64:7f Station UP: BSSID=d8:c7:c8:96:5d:90 ESSID=Castle Wireless VLAN=1 AP-name=Superintendent's Office
Nov 2 07:52:33 :522004: |authmgr| MAC=60:c5:47:5a:64:7f ingress 0x108a (tunnel 10), u_encr 32, m_encr 32, slotport 0x1040 , type: local, FW mode: 0, AP IP: 0.0.0.0
Nov 2 07:52:33 :522004: |authmgr| MAC=60:c5:47:5a:64:7f def_vlan 1 derive vlan: 0 auth_type 0 auth_subtype 0
Nov 2 07:52:35 :522026: |authmgr| MAC=60:c5:47:5a:64:7f IP=10.110.42.226 User miss: ingress=0x108a, VLAN=1
Nov 2 07:52:35 :522006: |authmgr| MAC=60:c5:47:5a:64:7f IP=10.110.42.226 User entry added: reason=Sibtye
Nov 2 07:52:35 :522004: |authmgr| Station inherit: IP=10.110.42.226 start bssid:00:00:00:00:00:00 essid: port:0x108a (0x108a)
Nov 2 07:52:35 :522004: |authmgr| {L3} Update role from logon to authenticated for IP=10.110.42.226
Nov 2 07:52:35 :522004: |authmgr| Reset BWM contract: IP=10.110.42.226 role=authenticated, contract= (0), type=Per role
Nov 2 07:52:35 :522004: |authmgr| station inherit IP=10.110.42.226 bssid:d8:c7:c8:96:5d:90 essid: Castle Wireless auth:0 type: role:authenticated port:0x108a
Nov 2 07:52:35 :522004: |authmgr| {10.110.42.226} autTable (" Unauthenticated authenticated ")
Nov 2 07:52:35 :522004: |authmgr| download: ip=10.110.42.226 acl=48/0 role=authenticated, Ubwm=0, Dbwm=0 tunl=0x108a, PA=0, HA=1, RO=0, VPN=0
Nov 2 07:53:00 :501095: |stm| Assoc request @ 07:53:00.380948: 60:c5:47:5a:64:7f (SN 194): AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:53:00 :501095: |AP PPS@10.110.42.24 stm| Assoc request @ 07:53:00.299646: 60:c5:47:5a:64:7f (SN 194): AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:53:00 :501100: |AP PPS@10.110.42.24 stm| Assoc success @ 07:53:00.300529: 60:c5:47:5a:64:7f: AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:53:00 :501065: |stm| Client 60:c5:47:5a:64:7f moved from AP Superintendent's Office to AP PPS
Nov 2 07:53:00 :501065: |stm| Sending STA 60:c5:47:5a:64:7f message to Auth and Mobility Unicast Encr WPA2 PSK AES Multicast Encr WPA2 PSK AES VLAN 0x1, wmm:1, rsn_cap:0
Nov 2 07:53:00 :500511: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Received disassociation on ESSID: Castle Wireless Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name Superintendent's Office Group Castle BSSID d8:c7:c8:96:5d:90, phy g, VLAN 1
Nov 2 07:53:00 :522036: |authmgr| MAC=60:c5:47:5a:64:7f Station DN: BSSID=d8:c7:c8:96:5d:90 ESSID=Castle Wireless VLAN=1 AP-name=Superintendent's Office
Nov 2 07:53:00 :522004: |authmgr| MAC=60:c5:47:5a:64:7f ingress 0x108a (tunnel 10), u_encr 32, m_encr 32, slotport 0x1040 , type: local, FW mode: 0, AP IP: 0.0.0.0
Nov 2 07:53:00 :522004: |authmgr| station free: bssid=d8:c7:c8:96:5d:90, valid=1, @=0x1089e054
Nov 2 07:53:00 :501080: |stm| Deauth to sta: 60:c5:47:5a:64:7f: Ageout AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office STA has left and is deauthenticated
Nov 2 07:53:00 :501100: |stm| Assoc success @ 07:53:00.387862: 60:c5:47:5a:64:7f: AP 10.110.42.24-d8:c7:c8:96:60:c0-PPS
Nov 2 07:53:00 :500511: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Received association on ESSID: Castle Wireless Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name PPS Group Castle BSSID d8:c7:c8:96:60:c0, phy g, VLAN 1
Nov 2 07:53:00 :500010: |mobileip| Station 60:c5:47:5a:64:7f, 0.0.0.0: Mobility trail, on switch 10.110.40.240, VLAN 1, AP PPS, Castle Wireless/d8:c7:c8:96:60:c0/g
Nov 2 07:53:00 :522035: |authmgr| MAC=60:c5:47:5a:64:7f Station UP: BSSID=d8:c7:c8:96:60:c0 ESSID=Castle Wireless VLAN=1 AP-name=PPS
Nov 2 07:53:00 :501105: |AP Superintendent's Office@10.110.42.37 stm| Deauth from sta: 60:c5:47:5a:64:7f: AP 10.110.42.37-d8:c7:c8:96:5d:90-Superintendent's Office Reason STA has left and is deauthenticated
Nov 2 07:53:00 :522004: |authmgr| MAC=60:c5:47:5a:64:7f ingress 0x10c4 (tunnel 68), u_encr 32, m_encr 32, slotport 0x1040 , type: local, FW mode: 0, AP IP: 0.0.0.0
Nov 2 07:53:00 :501000: |AP Superintendent's Office@10.110.42.37 stm| Station 60:c5:47:5a:64:7f: Clearing state
Nov 2 07:53:00 :522004: |authmgr| MAC=60:c5:47:5a:64:7f def_vlan 1 derive vlan: 0 auth_type 0 auth_subtype 0
I do believe that is similar to the issue that I am having with iPads as well.
I may have just figured out a work-around. However, this needs to be tested further. I don't know what the ramifications of changing this setting might have on other clients.
Here's what I'm looking at:
(host) #show wlan ssid-profile remote
Station Ageout Time 1000 sec
Now, decreasing this setting too far will surely have a negative impact on wireless VoIP. You really don't want those to age out that quickly. However, by aging out the mobile clients faster, they may re-authenticate and DHCP correctly. I'm not saying this is the answer, but definitely a direction to look into and play with in the lab.
I'll test it out and let you guys know what I find.
Zach
Zach Jennings
Contributor I
Do you think this could be some kind of bug? Has anyone opened a support ticket to address it?
I do have a TAC case open for this issue.
I'm trying again to replicate the issue to test some changes I made to the settings.
I don't have anything concrete yet. I'll post once I do.
Zach
Zach Jennings
Contributor I
We just got an AirWave appliance. It's sitting on my desk, and I'm in the process of setting it up. I noticed in the users section a lot of mobile devices (Apple, Motorola etc. MACs) are showing up as having IP addresses of 0.0.0.0. Is there a way I can set up the controllers to not allow these devices to associate? Or some way to automatically remove 0.0.0.0 MAC addresses from the user-table? Or something along those lines?
Contributor I
A bit more info:
When I'm connected and everything is working ok, if I roam with my mobile to another AP, the mobile stays connected, but I can't get any data through. I open a browser but can't get to any webpages.
Now, I've found that if I set a static IP address on the mobile, both this problem and the problem in the OP go away. I can always connect and roam with no problem. Leads me to think native there's something wrong with the way DHCP is handling these clients...
