ArubaOS and Controllers
Contributor I
Module DHCP Daemon is busy
anyone know which the reason of this message
"show running-config
Building Configuration...
Module DHCP Daemon is busy. Please try later"
Re: Module DHCP Daemon is busy
What version of code is this? How many APs? What are you using the internal DHCP server for and for how many clients?
Contributor I
The software version is 3.4.3.1
Almost 180 Ap's we have in each controller
Yes we are using the internal DHCP
We have almost 35 ip's dhcp pool for all our students university that connect almost 1000 users all day
Probably not what you want to hear, but you're really running past what the internal DHCP server was designed to do in terms of scale. You might try calling TAC, but you should really be looking at an enterprise class DHCP server if you're going to be handing out IPs at this scale.
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
