Occasional Contributor I
Monitor RAP-5WN snmp
Hello
Im using a rap-5wn with a Aruba620 mobility controller. Is it possible to use snmp against the mobility controller to get some info about the rap, i guess the rap itself dosnt support snmp monitoring.
Re: Monitor RAP-5WN snmp
Yes you can, through the controller. The ArubaOS MIB reference guide for your version of ArubaOS will tell you what to poll, based on what you need. It is located under Documentation on the support site. http://support.arubanetworks.com
Colin Joseph
Aruba Customer Engineering
