ArubaOS and Controllers
Monitoring DHCP scopes with SNMP
Is there a way to monitor a dhcp scope with snmp to see when the scope is almost used up. Doing a 'show user-table' only shows the connected users and not necessarily the ones that have disconnected but the lease is still active.
This is related to the old guest ssid with all the unauthenticated users consuming all the leases.
I can obviously do an snmp walk to get stats on connected users etc, but can't seem to find any related specifically to the dhcp scopes.
ACCP, ACCX #817, ACMP, ACMX #294
Re: Monitoring DHCP scopes with SNMP
There is none. The internal DHCP server is only meant for limited small scale deployments and is not meant to replace an enterprise-class DHCP server. You should look to an external DHCP server to get all the added features, functionality and reporting to achieve your goal.
