ArubaOS and Controllers
Monitoring Power Supplies via SNMP
We currently poll the switches for CPU, Temp, Interface stats....etc....
Now I want to add the power supplies into the mix (currently I would have no idea or alerting if one was lost of went bad).
Note: running 6.1.2.3 Aruba OS
The v6.1 MIB Guides shows 1.3.6.1.4.1.14823.2.2.1.2.1.18.1 for the power supply mib, and thats fine and I get back 1 for Good, and 2 for not present or powered off (seems there's only two values). I'd expected three:
1= good
2 = not present
3= present, but no power or bad....???
CLI (show inventory) does show more detail:
OK ( for all good)
Absent (obvious)
FAILED (if it's present but lost power, or power switched off)
