ArubaOS and Controllers
Monitoring RAPs with Cacti/MRTG
We currently deploy Aruba with RAPs only. Does someone know the SNMP OIDs for the following:
-Number of currently connected RAPs
-Number of devices connected to the RAPs
Re: Monitoring RAPs with Cacti/MRTG
On the support site, there is an ArubaOS management guide under documentation for each version of code, which details the OIDs you are looking for.
Colin Joseph
Aruba Customer Engineering
Thank you sir!
