ArubaOS and Controllers
Multiple IPs - Same Subnet - Same VLAN - Possible?
I think I know the answer to this, but thought i'd ask anyways in case i've missed something.
Is there a way of configuring a single VLAN with a single IP Subnet, with multiple IP addresses on that Subnet?
We've run into a strange setup that can't be changed, and would like to use an Aruba controller for it.
Aruba
Each VLAN has either no IP address (~L2) or a single IP address (~L3) on
the Aruba Controller.
