ArubaOS and Controllers
Frequent Contributor II
My APs all sitting on full power (g)
All my APs at various sites that run G are running on full power despite me using Spectrum Management. I've checked the min and max power, anything obvious that I've missed? Running the latest 3.4.0.3 code.
Thanks.
Full Power
Thanks.
There is nothing wrong with your access points running at full power. Spectrum Management is not a feature; "Spectrum Load Balancing" is a feature and it does not adjust the power. Adaptive Radio Management (ARM) would adjust the channel and power. To see why an access point is on a certain channel or power, you should use the "show ap arm history" command located here: http://airheads.arubanetworks.com/vBulletin/showthread.php?t=1036
