ArubaOS and Controllers
Frequent Contributor II
NPS simultaneous user (sessions) control
Anyone have NPS (new IAS+ Radius server)? or any idea about how set the system (Aruba controller & NPS server or IAS inclusive :( ) to control the simultaneous sessions that some triky users are doing (sharing his credentials with others)?.
This is a security breach (resources and control) like old times with ISP.
Free Radius and others old radius have this control like "Simultaneous-user = n" to do that. I don´t reach any Microsoft Document.
btw: The lap tops ARE NOT in the DOMAIN.
Re: NPS simultaneous user (sessions) control
If you are using captive portal, you can check "Allow only one active user session" under "Configuration" --> "Security", "Authentication" --> "L3 Authentication" --> "Captive Portal Authentication Profile"
If 802.1x, you can configure max sessions per user role under "Configuration" --> "Security", "Access Control" --> "Edit" next to the user role.
If you know the offending user you can also create a duplicate role that has the max sessions configured already and then set your authentication server rules to change that user to a that modified role.
