Contributor I
Nat issue
Hello there...
Here is the scenario.. i have a controller with a ip address 172.16.20.7 and the loopback is 172.16.20.6
the guest SSID (10.10.10.X) have is nat with this ip (172.16.20.7)
but i need another SSID (10.20.20.X) hide .... the question is the next ...
How can I do nat with another ip address which is in the same subnet (172.16.20.77)
Is it possible?
Frequent Contributor II
Re: Nat issue
I think you should be able to create new NAT pool, and then inside your firewall policy you should set the action to src-nat and choose that pool? That might work, but im not sure if ths ideal solution for what you want.
-ELiasz
ACDX, ACCP, CISSP, CWNA
Contributor I
Re: Nat issue
-ELiasz
Hi.. but can you be more specific please
