ArubaOS and Controllers
Occasional Contributor I
OS 5.0 configuration help
Hi Guys
I am pretty new to Aruba and would like to ask soemone advise on how to configure below. Thanks a lot.
- create a new Virtual Access Point profile with the following configuration details:
5GHz prefered 802.11n wireless network with spectrum load balancing (2.4 is usually more full these days and get the system to look for interference)
Use 802.1x authentication credentials for staff wireless connections
Ratification of firewall rules for captive portal access
Customisation of captive portal interface ( align the AISWA logo)
Set up separate IP pool for captive portal users and src-NAT
- populate AirPlanning information in the controller so coverage maps can be generated
- set up RAP profiles in the controller and base software upgrade the images to at least ArubaOS5
--------------------------hardware & Software----------------------------------
Wireless Controller model #: 650
Software Version: ArubaOS 5.0.3.0 (Digitally Signed - Production Build)
IP add: 10.0.0.85
AP model #: AP-105
Number of AP on the system: 6 so far ( ordered 2 more)
Re: OS 5.0 configuration help
Sir, that is quite a bit that you are asking. Have you read any of the documentation, so you can start somewhere?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks Collin.
Could you let me know how to add user's logo to the captive potal?
BTW, is this the right user guide I should look at: High-Density Wireless
Networks for Auditoriums Validated Reference Design
Thanks.
Aruba
I would start with the AOS 5.0 User guide.
Chapter 13, specifically, speaks to Captive Portal settings, including
logo.
logo.
Thanks. Can you provide a link for the user guide.
I can only find "High-Density Wireless
Networks for Auditoriums Validated Reference Design" guide and it's not the right one I think.
Cheers
the link to the 5.0 design guide is wrong
