ArubaOS and Controllers
OS 5 association problem
Hi
I' ve just upgradeed to 5.0.0.1 on a 620 controller and now I can't associate to any of my two SSID's (one Capt portal, one WPA2 with PEAP). The client are able to see the SSID's but they don't associate.
Switching to 3.4.0.4 I'm able to associate again. Back to 5.0.0.1 and the problem is still there.
Nothing happens when I try to associate. Some times the SSID's disappears (as seen from the client - Win XP SP3).
Anyone seen a problem similar to me?
Michael
User debug
Please turn on user debugging for that user to see exactly what is going on:
config t
logging level debugging user-debug
show log user-debug 100
Post that output so we can get a clue of what is happening. Is this a 802.11n wireless network? What type of encryption are you using?
obi
Contributor II
Re: OS 5 association problem
Try new 5.0.1.0 firmware?
