ArubaOS and Controllers
OS 6.1.1.0 user connection problem
We have just upgraded our system to 6.1.1.0, after that some of users says we can see the SSID but we cannot connect them.
We get a debug output from that mac address but we cannot find anything about problem.
We rebooted the AP that users try to connect, then users could be able to connect wireless network..
We saw this problem at few users again different times, on different access points.
I thing ramdom access points may be stuck and cant give service to users.
Is 6.1.1.0 is buggy?
Regards..
Re: OS 6.1.1.0 user connection problem
"An issue in which APs connected to a local controller ignore association requests from clients after a reboot has been fixed." - ArubaOS 6.1.2.2 release notes.
Please upgrade to ArubaOs 6.1.2.2 to fix that specific issue, if that applies to you. If you are not sure, please open a case with TAC to check on your specific issue.
It appears that this is still a problem in 6.1.2.2.
Can you provide more details about the problem(s) you're experiencing?
Charlie Clemmer
Aruba Customer Engineering
