ArubaOS and Controllers
Only able to power up one port out 8 with POE.
Hello;
I have and Aruba800-US running 5.0.3.3.
Recently I had unplug all of my of my directly connected AP65 from the mobility controller. However; only on of the 5 access points powered up after all of them where plugged back in.
My initial thought was the other 4 ports were damaged when I unplugged the access points, or the access points had failed.
This is not the case.
The AP65 on FE1/0 has power, the rest show off,
However they are all configured for POE.
Port Status Voltage(mV) Current(mA) Power (mW)
FE 1/0 On 48126 88 4275
FE 1/1 Off N/A N/A N/A
FE 1/2 Off N/A N/A N/A
FE 1/3 Off N/A N/A N/A
FE 1/4 Off N/A N/A N/A
FE 1/5 Off N/A N/A N/A
GE 1/8 Off N/A N/A N/A
After turning POE off on FE1/0, FE1/5 comes up.
FE 1/5 On 48126 52 4064
When I turn POE off on FE1/5, FE1/1 came up.
FE 1/1 On 47998 52 4942
I am was unable to find any useful information in the logs, and reboot the controller has not impact on this behavior.
At this point I am looking for ideas as to what could be triggering this behavior.
Re: Only able to power up one port out 8 with POE.
Sounds like a power supply failure on the 800 PoE controller. You should RMA it.
Really?
I would have thought that a power supply failure would have been more fantastic than that this. I will get with the support and put it in for an RMA.
Thanks for the advice.
-Curtis
