ArubaOS and Controllers
PSK on Aruba Controller?
I would like to add a PSK for authenticating Nortel 6120 phones. Can I do that?
Re: PSK on Aruba Controller?
Can you not just create a new SSID and use WPA(2)-PSK security then type in your PSK there?
Aruba
Controller Supports WPA and WPA-2 PSKs
You can utilize WPA and/or WPA-2 PSK networks on the Aruba controller (and thus access points).
Will give you a call to discuss further.
Found it thanks.
Aruba
Thx
Thanks Mark.
Glad it worked out.
