ArubaOS and Controllers
dpi
Packet Capture from CLI?
I've been trying to do a packet capture on a client from the Web GUI, but for some reason the button is not working. Tried with Chrome, Firefox and Explorer with no success. What are the other options for a packets capture from a wireless client?
Thank you.
Re: Packet Capture from CLI?
Please consult the document here: http://airheads.arubanetworks.com/vBulletin/attachment.php?attachmentid=192&d=1277808139 to do packet captures.
If that does not work, please let us know what steps you tried and what version of ArubaOS.
Great document, but I can't see the 'Interactive' check box. I've tried a few different controllers and APs, but it is never there.
Is this option to save to the AP still supported?
ACCP, ACCX #817, ACMP, ACMX #294
Not supported any longer, because the packet capture would then be saved to the actual AP, taking up valuable space. Before 802.11n this was not a huge issue. The document definitely needs to be updated.
